June 6, 2022 at 9:30 am
Watch & LearnParticipantIn this video designed with FSAE and BAJA student teams in mind, you will learn how to clean up and prepare geometry for FEA analysis. Free body diagram (FBD) indicating several forces coming on upright is shown. For questions and support, join the Ansys Student Community: https://studentcommunity.ansys.com/
