October 17, 2025 at 12:09 pm
SolutionParticipantThis example demonstrates how to model a realistic photon source and use it as input to qINTERCONNECT. The photon generation rate and wavefunction are calculated for a Type-I SPDC process in a localized segment of length L with a chi^{(2)} nonlinearity in a straight waveguide, where pump photons are converted to pairs of signal and idler photons such that energy conservation and phase matching conditions are satisfied. Interference between photons from two independent sources is demonstrated for identical and non-identical sources.
Read the full article here: https://optics.ansys.com/hc/en-us/articles/10867833819923
- Spontaneous Parametric Down-Conversion (SPDC) Photon Source
- Spontaneous Four-Wave Mixing (SFWM) Microring Resonator Photon Source
- Multi-Mode Interference (MMI) Coupler
- Small-Scale Metalens – Field Propagation
- Traveling Wave Mach-Zehnder Modulator
- Ring Modulator
- Integrated microlens and grating coupler for photonic integrated circuits
- Diffraction-Based Overlay Metrology System Design
- Volume Holographic Grating
- Large-Scale Metalens – Ray Propagation
