Licensing
Licensing
Spaceclaim throws disco_level1 license not available.
    • FAQFAQ
      Participant
      disco_level1 is the last license feature checked for Spaceclaim 2020 R1 or newer in its set of alternate licenses. The issue occurs when new license file is added which contains the alternate licenses but client does not recognise the new license due to old preferences. As a solution, please rename the following folders: %appdata%Ansys %appdataSpaceclaim Then check if Spaceclaim opening throws an option to set the alternate license.
