SpaceClaim starts instead of DM. When I doubleclick on Geometry in Workbench, Space Claim opens. How can I access DM?
Tagged: 18.1, fluid-dynamics, General, workbench platform
August 25, 2023 at 12:15 pm
SolutionParticipantThe default geometry editor is no SpaceClaim. To set DM as the default geometrty editor, go to Tools> Options> Geometry Import. Under General Options, change the Preferred Geometry Editor from SpaceClaim Direct Modeler to DesignModeler. Please see the attached image ‘2050312.jpg”.
- Skewness in ANSYS Meshing
