January 25, 2023 at 7:16 am
FAQParticipantHere are a few things to keep in mind when performing a Conjugate Heat Transfer (CHT) analysis which includes 3D surface bodies (baffles): 1). It is important to use the ‘Merge’ option (from the ‘Share Topology’ pull down list) when modeling baffle surfaces in the geometry (especially for conjugate heat transfer analysis). 2). While doing this, it is important to group all of the solid and surface bodies into separate components as different options will be applied to each of these components. 3). ‘Share’ option must be applied to the component comprising of solids. Please ensure that ‘None’ option is applied on the component with surface bodies. 4). Doing this will ensure successful creation of wall and wall-shadows in Fluent for performing conjugate heat transfer (CHT) analysis. Keywords: share / merge options, conjugate heat transfer analysis, 3D baffles, surface bodies, share topology
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
