March 17, 2023 at 2:15 pm
FAQParticipantThe following issues might occur during meshing updates in SpaceClaim Meshing: 1. Error message MultiZone blocking decomposition failed. and no mesh is created. 2. mesh created at different position than current geometry. Typically generated at the original position of the solid before movement. 3. some named selections are incorrect in the exported msh-file Some hints to prevent this issue are: – When using external components, internalize them before meshing. This also ensures that the Groups/Named Selections can be saved in the exported msh-file correctly. – Delete the blocking before moving bodies and re-create the blocking afterwards.
- ANSYS DesignModeler: Imprinting Geometry
- ANSYS DesignModeler: How to Perform a Clean and Repair
- ANSYS Workbench CAD Interface for NX: How To Create Named Selections and Parameters
- ANSYS DesignModeler: Shared Toplogy
- How to perform a subtract Boolean operation in SpaceClaim Direct Modeler?
- ANSYS DesignModeler: Weld Feature
- How to move component within the assembly?
- ANSYS SpaceClaim: Imprinting Geometry
- ANSYS SpaceClaim: Shared Topology
- Bidirectional CAD Interface Between ANSYS Mechanical and Creo Parametric 2.0
