Spaceball does not work in the Windows x64 version of Workbench 10.0 sp1. 3Dconnexion has a 64-bit driver, why doesn’t it work?
April 13, 2023 at 7:32 am
SolutionParticipantThe problem was that the Spaceball driver and Software Development Kit for Windows x64 systems was not available in time to make our release. We now have the SDK and have built the dll for the Windows x64 version of Workbench. The customer will need to: 1) Copy the attached dll into [Install Dir]ANSYS INCv100AISOLCommonFileswinx64 2) Then register the dll, as follows: %sytemroot%system32regsvr32.exe [Install Dir]ANSYS INCv100AISOLCommonFileswinx64Motion3DU.dll Some customers have reported that you also need to increase the sensitivity of the spaceball.
1. 476083.zip
