April 5, 2023 at 2:33 pm
FAQParticipantPlease check if you have ‘Clip to Range’ option on as shown in attached images. Once you click this option OFF, you will be able to see all contours. Also if its is poly mesh then its a defect and is been reported in R19.2.
- Skewness in ANSYS Meshing
