Some edges on faces or imprints from CAD model are not transferred to AIM/SpaceClaim upon import. What is workaround?
June 5, 2023 at 7:05 am
FAQParticipantThe issue is that by default, AIM/SpaceClaim simplify the geometry upon import. To disable this feature, go to the SpaceClaim Options > File Options > General > Disable “Clean and simplify geometry”. This will allow you to get imprints on faces imported in SpaceClaim.
- Skewness in ANSYS Meshing
