March 17, 2023 at 8:58 am
FAQParticipantThe operation may fail because of errors in the body geometry. You must remove the bad geometry before attempting to combine solids. Select the solids, and then select Check Geometry in the Inspect group of the Measure tab to identify any bad geometry.
- Skewness in ANSYS Meshing
