June 5, 2023 at 7:05 am
FAQParticipantTo match smoke visualization results, it’s desired to create a region inside the model to launch strealines. This can be done easily by using one of the principal planes (XY,XZ,YZ), then creating an isoclip on that plane. The isoclip is based on a local radius rr=sqrt((x-xo)^2+(y-yo)^2) (for the XY plane), where (xo,yo) determine the center of the circle. A user variable RR is created from the expression rr. An isoclip on the XY plane is generated where RR
- Skewness in ANSYS Meshing
