June 6, 2022 at 8:45 am
Watch & LearnParticipantThe ANSYS smart shape optimization tool is called adjoint technology. The tool is actually a solver that uses CFD simulation results to find an optimal solution based on stated goals (reduce drag, maximize lift over draft ratioreduce pressure drop, minimize or maximize heat transfer, etc.).. For more information visit http://goo.gl/9l83yz
- Skewness in ANSYS Meshing
