Tagged: 16, cfx, fluid-dynamics, General - CFX, graphics card
June 5, 2023 at 7:05 am
FAQParticipant1) You should always check the version of the driver of your graphics card. Install the latest version. Test out if your application is working with the general driver cfx5pre -gr mesa. 2) Sometimes the problem is related to the environmental variable for the language. Test out to set: lang us.utf-8
- Skewness in ANSYS Meshing
