Tagged: 19.1, mechanical, static, structural-and-thermal, structural-mechanics
May 15, 2023 at 8:32 am
SolutionParticipantPlease download attached presentation
1. 2054722_Simulation%20of%20Thermal%20Electric%20Generator%20-%20Presentation.pdf
