June 6, 2022 at 9:30 am
Watch & LearnParticipanthttp://bit.ly/1hHSIq5 Short Intro to tutorial & demonstration on how to reduce the effort for running fatigue simulations. The tutorial shows how to set-up and save a fatigue workflow and create a re-usable process that can be accessed with a single mouse click for future use. The model used for the demonstration is a wind-turbine responding to changing weather conditions over a period of 1 and 20 years.
