Silent installation of ANSYS suite when using multiple ISO images are mounted to different folders/drives
January 25, 2023 at 7:28 am
FAQParticipantTo run ANSYS installer without GUI, you can use this command line: [Windows, use Administrator login] ./setup.exe -silent -install_dir
-media_dir2 -media_dir3 [Linux, use ROOT login] ./INSTALL -silent -install_dir -media_dir2 -media_dir3 Example: Let’s says you have all 3 ISO files kept in /tmp directory, all 3 ISO files are mounted in separate folders named as ‘ansys2020R1DVD1’, ‘ansys2020R1DVD2’ and ‘ansys2020R1DVD3’. You want to install ANSYS under ‘/opt/apps/ansys_inc’ Go into /tmp/ansys2019R2DVD1 and run this command. ./INSTALL -silent -install_dir /opt/apps/ansys_inc -media_dir2 /tmp/ansys2019R2DVD2 -media_dir3 /tmp/ansys2019R2DVD3
