SHELL181 displacement results in X and Y directions can be plotted, but not listed or saved to an array. Z direction results are available regardless. Is this a bug?
March 17, 2023 at 9:00 am
FAQ
ParticipantThe PRNSOL, U, X command lists the nodal solution. When nlgeom, off, the UX and UY nodal displacement results are all zeros. With /ESHAP, 1, the UX results are shown at the pseudo points of the 3D expanded element geometry. The pseudo point displacements account for contributions from both nodal displacements and rotations. Therefore, the pseudo point displacements may not match nodal displacements. With /ESHAP, 0, the displayed UX will match listed UX.
- ANSYS Mechanical: Node Merge
- ANSYS Mechanical: Node Move
- How to use ANSYS Workbench Meshing Virtual Topology
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- How to use ANSYS Workbench for Shell Meshing and Editing
- What is the difference between shell 63 and shell 181?
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Merging Mesh Nodes
