Shell conduction run error message is: Checking contact points… Migrating 66 cell(s) across compute nodes
June 6, 2022 at 8:33 am
FAQParticipantThis error message can occur if the shell encapsulation method is not activated. This method is activated by default in release 2019 R1, but might be deactivated when an older cas-file is opened. To fix this issue enter the following TUI-command.
/define/models/shell-conduction/enhanced-encapsulation? yes
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
