Tagged: 17.2, cad-import, FLUENT Meshing/Tgrid, fluid-dynamics
August 25, 2023 at 12:15 pm
SolutionParticipantPlease refer to the attachment to access the solution.
1. 2046409.pdf
- Skewness in ANSYS Meshing
