March 17, 2023 at 1:11 pm
SolutionParticipantIn ANSYS Fluent, when density is modelled using ideal gas law, it is recommended to use an operating density value of zero. In such cases, users need to be careful in setting up boundary conditions for pressure outlets/inlets. In natural convection cases, where minor density differences (due to temperature variations) cause the flow, choosing the right operating density would be important for good convergence. This documents provides guidelines in choosing the best operating density values for such cases using an example.
1. 2041750_Corrected.pdf
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- Simulating Battery Pack Cooling System Using Ansys Fluent
- How to add comments to journal file so that I will know what each entry does?
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
