September 26, 2022 at 9:44 am
FAQParticipantIn some cases, you need to select all the inner faces of a model for performing operations like creating a group or defining boundary conditions. Since all inner faces are not easily visible, it becomes a challenge to select such faces. However, you can easily select all inner faces with a few clicks as shown below:
1. Click the Quick access button to open the quick access tools. Then select “Selection tools” option
2. Select the “Using Boundary” selection
3. Select all the capping faces of the body which represent the boundaries of the inner faces.
4. Next, select the Seed face tool
and select any one of the inner faces.
5. As soon as you select the seed face, all the inner faces bounded by the capping faces get selected.
- Surface to solid creation in SpaceClaim
- Ansys Discovery – Detect Tool
- Ansys Discovery – Working with Components
- Changing the visibility of bodies from transparent to opaque or vice-versa
- Discovery Quick Tip- How to update your geometry from a source CAD File
- FAQ – Share Topology is now available in Discovery 2021 R2
- Split Face in SpaceClaim
- Selecting all inner faces of a body
- Quick Tips for Volume extraction in SpaceClaim
- Stitch Faces & Split Edges Tools in SpaceClaim
