General
General
Select Solver not selectable
    • FAQFAQ
      Participant
      Symptom: Edit Mesh tab doesn’t show the select solver icon. Also in the Settings – Solver the default Solver can’t be defined. Solution: Delete the .aienv_options and cache folder. They can be found by going to Settings – General, hit apply and look up the path in the text window of ICEM CFD. After a restart the solver options are visible again.
