Tagged: 2021 R2, fluent, fluid-dynamics, General, Non-Reacting, Species/Reactions
March 17, 2023 at 8:59 am
FAQParticipantDuring initialization of a multispecies case the following segmentation faul can occur under certain conditions: Node 3 Fatal signal raised sig = Segmentation fault 570f8120 CX_Primitive_Error 656d0cc0 seh_filter_exe 5719ec80 logical_right_shift 55d7ec30 _C_specific_handler 67ff1f80 _chkstk 67fa1020 RtlRaiseException 67ff0ba0 KiUserExceptionDispatcher 54de35b0 Switch_Species_Data This was observed for a case with a inlet species mass fraction being defined by an expression that depends on report definitions, i.e. (-1*{outlet_air}*{outlet-air-co2}*1[s kg^-1])/(0.0034) The expression result in this case actually is correctly non-dimensional and so the expression is correct. Workaround is to 1. set the expression to a constant value, i.e. 0 2. initialize 3. revert the expression to the original setting 4. start solver This issue does not occur in 2022 R1 and following.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
