Tagged: 2020 R1, edt, error, HFSS - SYS, Installation Process, Installation/Licensing/Systems, N/A, startup, unknown
January 25, 2023 at 7:28 am
FAQParticipantResults from ansyscl.exe 2019R3 not being updated. To resolve: 1. stop all AnsysEM applications 2. archive/rename C:Program FilesAnsysEMShared Files 3. Add/Remove Programs – Select “Change” on “ANSYS Electromagnetics Suite 2020R1” – Select “Repair” option 4. When complete, a new C:Program FilesAnsysEMShared Files will be created.
