January 13, 2026 at 7:52 am
FAQParticipantA frequent question we receive is whether Explore results can be saved and reopened later. Previously, only Discovery Refine results could be saved to the .dsco file. Starting with the 2026R1 release, you can now save Explore mode results, allowing you to view them without having re-solve.
This document explains how you can do it.
Saving Discovery Explore Results to File
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Discovery – Defining new material
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Structural Simulation using Bolt Idealization
- Discovery Quick Tip- How to Export to Fluent
- Thermal Analysis of Heat Sinks with Ansys Discovery
