Discovery Physics
Discovery Physics
Saving Discovery Explore Results to File
    • FAQFAQ
      Participant
      A frequent question we receive is whether Explore results can be saved and reopened later. Previously, only Discovery Refine results could be saved to the .dsco file. Starting with the 2026R1 release, you can now save Explore mode results, allowing you to view them without having re-solve.
      This document explains how you can do it.
