Running SpaceClaim 2019R2 produces either Request name 16064 or ANSYS Additive Prep does not exist in the ANSYS Licensing pool. How do i stop this error? SpaceClaim will still open after clicking OK.
April 13, 2023 at 7:32 am
SolutionParticipantTo stop this error from popping up, open up SpaceClaim, go to: File->SpaceClaim Options->Add-Ins Uncheck Additive Prep. See Attached PDF for full instructions and screenshots.
1. 2059178.pdf
