Licensing
Licensing
Running Fluent with SLURM. Throw error “terminate called after throwing an instance of ‘std::runtime_error’ what(): locale::facet::_S_create_c_locale name not valid”
    • FAQFAQ
      Participant
      This is related to node configuration. That error shows, locale settings on the host(s) are invalid or not correctly set. Do you get an error on the compute node when executing the “locale” command? Once you fix the node configurations to have the “locale” command work properly, the fluent error will be solved.
