Running an electromagnetic simulation in AIM 18.0 based on the Magnetics template, returns a zero Magnetic Force magnitude. This was not the case with previous releases.
Tagged: 18, AIM - SYS, Installation/Licensing/Systems, Operating System, Other, rsm
June 5, 2023 at 7:05 am
FAQParticipantThis is a known issue for AIM 18.0 running on non U.S. windows operating systems (e.g French, Polish, etc.). The issue is resolved for Release 18.1
