RSM error: qsub:Bad UID for job execution qsub: Bad UID for Job execution Failed to submit job to cluster.
Tagged: 17, Installation/Licensing/Systems, Mechanical - SYS, Remote Solve, rsm
April 5, 2023 at 2:32 pm
FAQParticipantThe error message has been invoked by PBS JS. Solution: 1. Please make sure that the Linux RSM services has been started using normal user instead of root. 2. PBS profile absolute PATH should be included in the Linux PATH variable. 3. The submission host should be added in the client RSM.
