June 5, 2023 at 7:05 am
FAQ
ParticipantThis solution will show you how to reduce the memory used to display movement and rotation for large meshes. In the Display Options panel, change the Animation Option to Wireframe. By using Wireframe, the display memory can be significantly reduced. Additionally, the point you click on with the middle mouse button becomes the center of the display so you can use this to move the display very quickly. The clicked point also becomes the center of rotation.
- Skewness in ANSYS Meshing
