May 25, 2023 at 7:30 am
SolutionParticipantIt becomes occasionally useful to examine in closer detail the quality of the solution of some applications in frequency domain when the material properties are also complex. Typically those cases involve materials such as lossy ferrites and/or lossy dielectrics. When the nature of losses is also due to magnetic and/or electric hysteresis (and thus in addition to ohmic losses which also occur if electric conductivity is non-zero), Maxwell allows to model such effects using complex permeability and/or permittivity by allowing the specification of the tangent of magnetic / electric loss (angle). Example project is attached. Keywords: Complex BH, loss, cache
1. 1839.zip
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- Cloud Computing from Electronics Desktop
- What are the available boundary conditions in Maxwell?
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- ANSYS Electronics Desktop: Simple Communications Channel For Signal Integrity Analyses – Part III
