” Rank = #: Process affinity not being set computer_name has other FLUENT parallel processes running.”
Tagged: 19, FLUENT - SYS, HPC/Parallel, Installation/Licensing/Systems
May 15, 2023 at 8:33 am
SolutionParticipantPlease see attached resolution document for a complete explanation of FLUENT and Processor Affinity.
1. 2039823-processor-affinity.pdf
