Question: Why am I getting this error when trying to load Fluent UDFs? LINK : fatal error LNK1104: cannot open file “kernel32.lib”
Tagged: 17, Compiler Support, fluent, FLUENT - SYS, FLUENT_INC, Installation/Licensing/Systems, N/A
January 25, 2023 at 7:28 am
FAQParticipantAnswer: Check the environment variables that there is no FLUENT_INC variable defined. If there is delete it. Additionally, check the Path variable that there is no reference to Fluent in the path. If there is delete and try loading your UDF again.
