Question: What should I do if RSM 18.2 jobs submitted to PBS Pro on Linux run into the following error Submit Failed. ApplicationName=’qsub’, ….Native error= Cannot find the specified file System.ComponentModel.Win32Exception: ApplicationName=’qsub’, CommandLine=’ ….. Native error= Cannot find the specified file
June 5, 2023 at 7:05 am
FAQParticipantAnswer: Use “which qsub” command on linux to determine full path to qsub and add that to /ansys_inc/v182/RSM/Confot/tools/linux/rsm_env_profile e.g. Use putty ssh to login to the machine running job manager and run which qsub if the path shown is /cm/shared/apps/pbspro/12.1.1.131502/bin/qsub Then apply the path and login as user who can edit the rsm_env_profile and add a line export PATH=$PATH:/cm/shared/apps/pbspro/12.1.1.131502/bin What causes this error: The command in the error is likely in your path when you interactively login say using putty ssh. However, the operating system may be handling non interactive login differently causing the issue. The complete error may look like below Submit Failed ApplicationName=’qsub’, CommandLine=’-l select=1:ncpus=1:mpiprocs=1 -N “RSMTest” -q workq -V -o “/rsm/abcdefgh.ijk/stdout.rsmout” -e “/rsm/abcdefgh.ijk/stderr.rsmout” “/rsm/abcdefgh.ijk/clusterjob.sh”‘, CurrentDirectory=’/rsm/abcdefgh.ijk’, Native error= Cannot find the specified file System.ComponentModel.Win32Exception: ApplicationName=’qsub’, CommandLine=’-l select=1:ncpus=1:mpiprocs=1 -N “RSMTest” -q workq -V -o “/rsm/abcdefgh.ijk/stdout.rsmout” -e “/rsm/abcdefgh.ijk/stderr.rsmout” “/rsm/abcdefgh.ijk/clusterjob.sh”‘, CurrentDirectory=’/rsm/abcdefgh.ijk’, Native error= Cannot find the specified file.
