Question: What should I do if I run into “The FLUENT application failed to start” ? My homedrive and homepath are set to a network location.
Tagged: 2019 R3, failed, fluent, FLUENT - SYS, Installation/Licensing/Systems, Operating System, Other, start, workbench
January 25, 2023 at 7:28 am
FAQParticipantAnswer: In rare cases when a network drive is used as a home drive home path, (due to reasons not yet completely understood) there can be issues starting FLUENT or Icepak. As a workaround please try using a 3 line batch file like the below to start FLUENT standalone and Workbench. The batch files can be saved to a preferred location or the desktop and be double clicked on to launch FLUENT or Workbench using an alternate location for HOMEDRIVE and HOMEPATH. This example uses D drive and ANSYS_Startup as an example
set HOMEDRIVE=D: set HOMEPATH=ANSYS_Startup “C:Program FilesANSYS Incv195fluentntbinwin64fluent.exe” -r19.5.0 -shortcut set HOMEDRIVE=D: set HOMEPATH=ANSYS_Startup “C:Program FilesANSYS Incv195FrameworkbinWin64runwb2.exe”.
