Question: Using Product Launcher to launch LS-DYNA with SMP on local machine results in error: Error connecting to the Service [mpiexec@hostname] .. hydrautilssocksock.c (270): unable to connect from “hostname” to “hostname” (No error)
June 5, 2023 at 7:05 am
FAQParticipantAnswer: Install Intel MPI by running this file as Administrator. Right-click on it and select ‘Run as administrator’. C:Program FilesANSYS Incv180commonfilesMPIIntel5.1.3.180Windowsw_mpi-rt_p_5.1.3.180.exe
