June 5, 2023 at 7:05 am
FAQParticipantAnswer: This message indicates that the user is trying to install without extracting the downloaded .zip file first. Have the user extract the .zip file and then run setup from the extracted directory. It is recommended to use the Windows extraction utility rather than a 3rd party zip utility.
