Question: Running Sherlock I encounter the error “Request name 16301 does not exist in the licensing pool. License server system does not support this feature.”
January 25, 2023 at 7:28 am
FAQParticipantAnswer: The ANSYS License Manager on your license server machine needs to be updated with the 2019 R3 version of the license manager.
