Question: Running Sherlock 2019R3 I encounter the error “Could not connect to any license server. Please use ANSLIC_ADMIN to setup your license server.”
January 25, 2023 at 7:28 am
FAQParticipantAnswer: Please install ANSYS Mechanical to configure the Client-side licensing components which are required for use with Sherlock. Sherlock R3 also requires ANSYS Mechanical for proper functionality.
