Question: My HFSS appears stuck with status bar showing “MPI based solver Distribution”. What can I do ?
Tagged: 18, HFSS - SYS, hpc, HPC/Parallel, Installation/Licensing/Systems
June 5, 2023 at 7:05 am
FAQParticipantAnswer: At release 18 ANSYS EDT does not show status bar update for each frequency point. In reality the solution should be in progress. Please right click solution to launch profile to monitor the progress.
