Question: License manager 2020R1 not starting with dongle license, ANSYS License Management Center may not be ‘seeing’ the dongle hostid
January 25, 2023 at 7:28 am
FAQParticipantAnswer: First perform these 2 steps prior to installing the update. 1) Copy the lmutil.exe from unzipped of C:Program FilesANSYS IncShared Filesbinwinx64driversflexnet11_16_4_0.zip 2) Move the lmutil.exe to replace the one in C:Program FilesANSYS IncShared FilesLicensingwinx64 (assuming you installed ANSYS License Manager in default location) You may now update the dongle drivers to 2020R1 as listed in the ANSYS Inc Licensing Guide documentation.
