January 25, 2023 at 7:28 am
FAQParticipantAnswer: for FLUENT 14.5 and higher command line option -feature_parallel_preferred=
can be used for example -feature_parallel_preferred=anshpc_pack -feature_parallel_preferred=anshpc -feature_parallel_preferred=acfd_par_proc This was also added to MAPDL at 16.0. The MAPDL command option is -ppf
