January 25, 2023 at 7:28 am
FAQParticipantAnswer: Please use the steps below to reset client license preferences example below uses version 20.x On the Client/Workstation: First close all ANSYS programs saving data where necessary For WINDOWS please select – Start /All Programs /ANSYS v20.X / ANSYS Client Licensing / Client ANSLIC_ADMIN Utility. or click type “Client ANSLIC_ADMIN Utility 20.x” in windows search and launch the utility For LINUX –
/ansys_inc/shared_files/licensing/lic_admin/anslic_admin click on “set license preferences for user ” –> 20.x –> OK –> Reset to default -> Continue -> OK
