January 25, 2023 at 7:28 am
FAQParticipantAnswer: To remove the Electromagnetics Suite silently under Windows please start the command prompt and run the following: “C:Program FilesAnsysEMAnsysEM20.2Win64Uninstallsetup.exe” /runfromtemp /z suppressconfirmation /removeonly
