January 25, 2023 at 7:28 am
FAQ
ParticipantAnswer: The ANSYS Licensing Portal (https://licensing.ansys.com/index.html#/) allows you to view current license files, download license files, rehost license files, deactivate license files and review license server history. To change your license server using the ANSYS Licensing Portal, please refer to this tutorial video. https://www.youtube.com/watch?v=U2Tkul6DwTI
