Question: ANSYS RSM to a remote system used to work fine in the past. What should I do if I am getting an error “”Failed to validate credentials: System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 127.0.0.1:9190” ?
January 25, 2023 at 7:28 am
FAQParticipantAnswer: RSM Launcher may have started before the network was ready on the remote machine. On the remote machine go to Windows “Services” and stop and start the ANSYS RSM Launcher service. This should resolve the issue. To prevent this from happening again you can right click ANSYS Launcher service and from properties change startup type from Automatic to Automatic Delayed Start.
