March 27, 2026 at 6:45 am
FAQParticipantDiscovery 2026R1 introduces a capability of using Query Editor to obtain an advanced selection set. You can write a query for active and visible components by using various criterion and operators. Query Editor makes it easier to select the features based on a logical query and create advanced named selection on your geometry for faster and easier pre-processing and simulation setup.
Query Editor in Ansys Discovery
- Surface to solid creation in SpaceClaim
- Ansys Discovery – Detect Tool
- Ansys Discovery – Working with Components
- Changing the visibility of bodies from transparent to opaque or vice-versa
- Discovery Quick Tip- How to update your geometry from a source CAD File
- FAQ – Share Topology is now available in Discovery 2021 R2
- Split Face in SpaceClaim
- Selecting all inner faces of a body
- Quick Tips for Volume extraction in SpaceClaim
- Stitch Faces & Split Edges Tools in SpaceClaim
