Q: Why error “Error: Build Grid: Aborted due to critical error” is prompted in FLUENT trying to import a 2D mesh made with ANSYS ICEM?
Tagged: 19.2, fluid-dynamics, icem-cfd, Solver output
March 17, 2023 at 8:58 am
FAQParticipantA: ANSYS ICEM can export a 2D mesh without the error only if it is located in the plane XY.
- Skewness in ANSYS Meshing
