Q: Why do I receive the following error message when starting ANSYS 2019 R1 APDL and before the launcher window could come up: ANSYS Product Launcher Failed to get environment variable PATH, so cannot update PATH variable
March 17, 2023 at 9:01 am
FAQParticipantA: The user’s PATH environment variable appears quite long. After shortening the PATH variable the application worked.
